I'm guessing that you have a mechanical hard drive in your Mac. Switching to an ssd will increase the 4k IOPS read/write speeds of the drive which should allow for higher transfer speeds for a more extended period of time. This is assuming that you did not coincidentally start overloading your home network once you started the file transfer.
print "Hello World!" ("Hello World!")
https://linustechtips.com/topic/929066-help/#findComment-11361930
I'm guessing the file transfer speeds are good while the file is being transferred to the hard drives internal cache (memory if you will). Once the cache is full and it has to actually start writing to the platter... the speeds drop off.
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
https://linustechtips.com/topic/929066-help/#findComment-11362060
Well I don’t have internet at all it’s just one end of Ethernet pot in a pc to the other
https://linustechtips.com/topic/929066-help/#findComment-11362287
