First build (mostly for gaming) and need thoughts/suggestions on where I can save money and where to invest money
Solved by redsquirrel0249,
RAM is good, storage is good. 550w PSU should be fine. You can tell yourself that a 750w PSU is an upgrade path, but for the most part, GPUs and CPUs are only going to get more efficient. I would suggest a different balance of CPU and GPU. Imo, 1700X could use some more graphics power, but it all depends on what you're doing with it. I'm running a Ryzen 5 1600 with a 1070 and that's relatively balanced.
I'd recommend adding a SSD boot drive as well. @itisme911 Had a good point about usage of your M.2 port, so that's also an option if you're interested in some higher speed storage.
