I plan on rebuilding a new gaming PC, I intend to use a i7-7700k with a GTX 1060 and 16gb ddr4 ram, the usual. I really want a completely modular power supply but have no idea on what wattage I need, I do NOT plan on overclocking the CPU. Can someone please give me some advice?
https://linustechtips.com/topic/927319-power-supply-recommendation/
Do you already have the CPU? If not, don't.
What's available?
The cheapest thing would probably be Bitfenix Formula, be quiet Pure Power, though the Bitfenix is better.
"Hell is full of good meanings, but Heaven is full of good works"
Fully modulair huh? The corsair rm550x should be fine. Maybe the rm650x or rm750x for future upgrades?
My main rig  Shardsedge
 ☟ INFO & SPECS
  • Information:
This build is made for video editing, Gaming and livestreaming.
probably 65% of this build has been bought used.
  • Specifications:
CPU  AMD Ryzen 7 1700
GPU  Sapphire RX 580 PULSE 4GB
SSD ✦ Toshiba TR200 240GB
HDD ✦ WD Black 160GB 2.5" + WD BLUE 1TB
PSU ✦ Corsair RM750X
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 3000Mhz
CASE ✦ Corsair Crystal 460X
MOBO MSI X370 SLI Plus
My old pc build  Smoke
 ☟ INFO & SPECS
  • Information:
This build was made for gaming especially, it was my second build.
i had some struggles livestreaming on it because the CPU just wasn't good enough for that.
(I do not have this build anymore)
  • Specifications:
CPU ✦ Intel i5 6500
GPU  Sapphire NITRO+ Radeon RX 470 4G D5
SSD ✦ Kingston SSDNow v300 120GB
HDD ✦ WD Blue 1TB
PSU ✦ Corsair CX450M
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 2400Mhz
CASE ✦ Sharkoon S25-V
MOBO ✦ MSI H110M ECO
Why?!
For a System that doesn't even consume 300W....
Just now, Stefan Payne said:
Why?!
300 W? Well the rmx series are REALLY good and dont go lower than 550 watt. And it is always good to have alittle more wattage. Dont cheap on wattage or psus. Never. I mean what if he like puts a sli 1070 in the future in hes pc. He doesnt need to switch from psu than.
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
What's available?
Nonono dont get just the cheapest thing. Cheaping on a PSU is the worst thing you can do.
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
U could also go for the seasonic focus plus 550 gold. Its a good one too
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
Why not go lower than 550W? With 450W he can run an HEDT 1080 Ti system and still have room left over. And do keep in mind that PSUs from any decent brand are rated to run at full power at their max rated temperature 24/7 for the entirety of their warranty.
Going for 1070s in SLI doesn't make sense. Neither does recommending based on that scenario. Why don't you recommend an AX1600i in case he decides to go LN2 overclocking with an 7980XE and a Titan V?
The power use goes down with newer gens, not up.
He's recommending the cheapest good PSUs. As you could see by the models he was recommending.
Just now, Wolf ~ IRONI said:
300 W?
Yeah, at most, with Prime Running, bit of overclock and the Donut rendering in the Background, maybe.
With normal Gaming (60Hz and VSYNC ON) probably more like 200-250W.
Yeah, that's why that's the normal recommendation.
But Alternatives:
Cougar GX-F
Bitfenix Whisper M
He doesn't if he switches to a Threadripper and VEGA 64...
And the Differences between 550W and 650W aren't that great usually.
Bit here and there...
Just look at those:
https://www.tomshardware.com/reviews/corsair-rm650x-psu,4611-3.html
https://www.tomshardware.com/reviews/corsair-rm550x-power-supply,4484-3.html
Secondary Side, no difference.
So the only Difference is in the PFC and Primary Switching stages.
And if you happen to live in a 230VAC Country, that doesn't matter one bit for you...
The RMX series doesnt go lower than 550watt. Please read before commenting
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
Wait so should I get the i7 though?
NO!
Its shit, only has 4 Cores, you can't put an 8k i7 in the same Board, so upgrading is impossible...
You should look in the direction of a Ryzen 2600(x) with an X470 Board.
With the 300 Series you need to Flash the BIOS somehow...
Whisper M does.
Be quiet Straight Power 11 also
Well u could always go for amd ryzen if u want some more performance in video editting n stuff. But intel will be faster in games
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
Man i hate ppl who cheap on psus. I mean if your psu dies ur system dies mostly. Go w a high quality psu bro.
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
Well, I read this part
As in, "the RMx is really good, also don't go lower than 550W". A bit of confusion, my bad.
For video editing, depending on the task, Intel Kaby and Coffee is faster. Look at Puget's testing in Adobe CC.
I wouldn't count on it that much...
https://www.heise.de/ct/artikel/Exclusive-Spectre-NG-Multiple-new-Intel-CPU-flaws-revealed-several-serious-4040648.html
and the Adobe CC Test I've seen are garbage -> DDR4-2400 for the one, the other had 2666....
And they were before the Spectre Patches! And only 1000 series...
So totally useless...
For video editing, I wouldn't bother even thinking about Intel right now because the Performance Impact of those Patches on high I/O Tasked Stuff is very high.
So I'd avoid Intel if possible..
The next thing is RAM, should be at least 16GB, the more the better. But with Ryzen don't forget the Memory! With DDR4-3200 you get something like 10-15% over DDR-2400...
And of course a good, big NVME SSD wouldn't be a bad idea either if you are handling big files either.
Newest Premiere updates heavily favor Intel and still have issues with crashing during rendering and playback on Ryzen. I wouldn't buy a Ryzen chip if using Premiere. Source: I have both the latest edition of Premiere Pro and a 1700X.
Also, new CC updates have acceleration for Quick Sync which makes an 8400 faster than an 1800X at any task in Premiere.
