Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/926594-no-8-pin-cable/#findComment-11338963
You can technically run an 8pin CPU off of just 4pins, Austin Evans among others have done it in the past(myself included).
That said, I wouldn't recommend it. You'd be better off getting a new PSU.
https://linustechtips.com/topic/926594-no-8-pin-cable/#findComment-11338985
yeah i can confirm, i've done this in budget builds aswell.
just plug the 4 pin plug into the 8 pin connector. it should fit on one side.
that being said tough, i also very much agree that a better PSU is the better solution here.
https://linustechtips.com/topic/926594-no-8-pin-cable/#findComment-11338997
19 minutes ago, emosun said:
if the power supply is crappy enough to not have an 8pin connector then don't use that power supply.
He has an G1840, a GTX 560, and some 300w OEM PSU by the looks of his previous posts. So while a new PSU is technically ideal, it's not really worth putting money towards.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/926594-no-8-pin-cable/#findComment-11339021
42 minutes ago, The321 said:
I have a Psu with a 4 pin connector and I want to power a 8 pin cpu with it. The cpu is very low power (60w) how can I do this since it only accept 8 pin (the motherboard )
Don't bother with adapters unless you want to have exciting fires.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/926594-no-8-pin-cable/#findComment-11339078
What PSU do you have exactly??
Because those without 8pin I can recall are either ancient, SFF or garbage.
Could you pls make a picture of the Label and post it here?
Do you know how old it is??
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/926594-no-8-pin-cable/#findComment-11339082
I wouldn't. They can get hot. What PSU? If its quality one, you should be fine. But just to note that those splitters are for GPU power, not CPU. So you are better off getting newer PSU than buying splitters for CPU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/926594-no-8-pin-cable/#findComment-11339489
