Glitch and lag on Galaxy S7
Solved by Airdragonz,
There are a few possibilities based on your description. Chances are, you have something running in the background (most likely malware) that's taking up the cpu. There's also the chance (and very very unlikely) that your cpu/battery is being heavily thermal throttled. And unless you have rooted or installed a custom kernel on your device, it is unlikely that your cpu scheduler has been messed up. I would just back up all data and go ahead with a full wipe.
