I think the best upgrade you could do is get a better GPU.
https://linustechtips.com/topic/924571-some-upgrade-required/#findComment-11319280
6 minutes ago, LordFarto said:
Hi, this is my actual build https://pcpartpicker.com/list/WHVt8Y. I think is quite good but sometimes some games are slow and it lose frames.
Should I upgrade some parts?
Thank you very much!
A 1080/ti and overclocking you CPU would basically max out the capabilities of your system.
https://linustechtips.com/topic/924571-some-upgrade-required/#findComment-11319292
Usually a loss in FPS is either a CPU limitation or a GPU limitation. Your CPU is pretty set unless you want to overclock it and but the GPU is more likely your limitation for the intensity of graphics you're running. Anti-aliasing (if applicable) can really put a dent in your fps which is a GPU limitation along with high detail in games. Consider that and see if AA is enabled. If disabling it makes the games smoother then it's a GPU limitation.
https://linustechtips.com/topic/924571-some-upgrade-required/#findComment-11319300
Just now, Zmax said:
GPU is close to mine 960, very close to replacement time.
The problem is cost. Wait , the cost of card is about to fall. Miners are moving in a different direction,from what I have read , could be false, but we can hope.
also rumors have it that the next lineup of nvidia gpu's is about to be announced in a month or two
https://linustechtips.com/topic/924571-some-upgrade-required/#findComment-11319304
2 hours ago, LordFarto said:
Okey, i will wait :)
Also I wanna change the case, any recommendations?
Thank you everyone
don't hold your breath about the next GTX series cards though. we don't even know if they are sticking with the previous naming convention yet. but still, go ahead and wait around until we at least know, which should definitely be within the next few months. all i can suggest for now though is to turn down your settings just a little bit.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/924571-some-upgrade-required/#findComment-11319411
