Display port for 1440 144mhz ?
Go to solution Solved by Glennieboyyy007,
also this is the answer i was reffering to
1) 2560x1440 @ 144Hz-. DP1.2 temp.thumb.png.2f72b35a288d61a884e834622908a009.png
Can you recommend me a display port for 1440 and 144 mhz ? Because with so many options and brands i dont know which one can support it ...
5 minutes ago, Glennieboyyy007 said:
tried google? this is the first result
all i get is wikipedia info ... i want a specific one that can do it. unless all can do it , which i assume i will find out by reading wiki ? Hmmmmmmmm
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
