I'm going off to college next year, I will not be taking my desktop with (at least first year) so I won't have anything to play any games on until I decide to bring it. I'm completely torn between the two. I won't be for the most part playing games (obviously) and I need something that is good for a CS major and general college classes. I've been a long time Windows user ever since I can remember, I also have used macOS since my school uses it and my parents also have macs as well. So usability between the operating systems isn't a concern. In addition, another reason why I'm considering the MacBook is that I would like to gain more experience in other operating systems. Also price isn't really an issue.
Sorry that my thoughts are all over the place, which one do you think is best for my situation. Thanks in advance to everyone that contributes.
https://linustechtips.com/topic/923841-razer-blade-or-macbook-pro/
Neither, get something with a better price to performance like Asus and MSI
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
For your use case scenario you will be mainly using Linux and a bit of Windows I believe. I would not recommend a Mac.
They are both kinda overpriced though :P.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
For Computer Science? A Mac is perfect. They have the largest compatibility with their ability to run macOS and Windows 10 (and linux with some tinkering) natively. You will never not be able to do something in any of your courses with a MacBook.
If you want to do some gaming, and price isn't an issue...then a 15" with a Radeon Pro GPU will get you playing basically every game (not at native resolution of course)
13" MacBook Pros are only equipped with dual core hyper-threaded CPUs and Iris Graphics. Enough for light gaming at 900p on low/medium settings. And of course 4K video editing in FinalCut Pro. Not sure how demanding your courses are but these are solid options.
15" MacBok Pros run true quad cores, and have dGPUs. These are the best options both for versatility and long life spans.
I am biased towards the Mac, but if I could upgrade to a 15" with a Radeon Pro 560 I would do it in a heartbeat just because it is nice to know I have all that GPU power even if I do not need it.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
Of the two, the Mac without a question.
At least that machine will work even when throttled. The Razer Blade, on the other hand, is a mega mess.
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
Both trash, go for an MSI laptop.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
Eh, I wouldn't recommend just any MSI laptop.
Only the GE Raider, GS75 and GT line I recommend. Everything else is pretty mediocre.
Keep in mind, it's for coding and computer science. I doubt he wants a gaming machine anyway
1 minute ago, D13H4RD2L1V3 said:
Eh, I wouldn't recommend any MSI laptop.
My main computer science/coding rig is actually in my sig (The Oldie). It's just a modded 2006 dell inspiron 530 and runs a hell of alot more stable than a mac or any laptop out there, plus it's never broke in its 12 year life span. Recommending MSI due to the GT line, they're pretty good little laptops for the money and do anything you throw at them pretty much.
The GT line is a very capable laptop and has excellent cooling. That's why I recommend them.
For the OP though, maybe it's a bit much because it is also quite big, and I'm unsure about his aesthetic preferences either.
Reason why I recommended the MacBook Pro was its platform. I think being proficient in multiple platforms is a pretty strong pillar for many CS students (as a CS student myself) and because you also need a Mac to code for iOS (yeah, it's unfair but nothing about Apple has really been fair, lately at least). It's not the best machine for everything but for a CS student, it's not that bad of an option.....provided you can splurge.
Personally, I would go for a 2015 model. The new models still don't do it for me and even though the 2015s still run on Haswell processors, they're still more than capable enough to run many applications.
