Connecting two Houses
El-Nino
Hello boys and girls
I have the following situation:
I've built a house near my parents house. During construction i layed a Cat6A cable to physically connect the two houses. Both have their own modem (different provider) and router.
My goal is to give my parents access to my server.
How can I do that?
ima thinking you should just be able to connect the cable to their router and your server should show up as a network location and they should be able to access it.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
to clarify: I still need access to the server for myself. So it needs to be in both networks.
If I just connect the two networks, I'll end up with two DHCPs running in the same network.
One idea would be to add another network card to the server, so it can be in both networks.
How can I do that?
Adding another NIC is the easiest solution. Running 2 DHCP servers in the same network is a bad idea.
Especially when working with Active Directory DNS. Because it will conflict on both IP addresses.
The geek himself.
Or consider sharing an internet connection. Switch to just the one connection, upgrade it to handle usage and share the cost.
Then you just have the one network running and it's a simpler approach.
Alternatively, add a second NIC to your server to allow access that way.
