Do this air flow look okay?
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
https://linustechtips.com/topic/923481-optimal-air-flow-bit-fenix/
well you will have the CPU cooler fighting the exhaust fans over where the air goes, but its probably fine
Builds:
here is a bigger irony, my cpu cooler is actually facing the side of the case...blowing hot air out to the opposite side of the PCI-E. This is just a picture that I got off the net and photoshopped.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
ahh then its fine, the stock cooler sucks air down but if you have some tower style cooler this looks better
Builds:
thanks!!!
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
do you recommend that I reverse the back exhaust fan so it faces the front?
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
What are your specs?
Having 2 exhaust fans at 1/2 speed and front at full speed would bring it close to neutral. But for positive you need to remove one of exhausts.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
i7 3770k
8gb Samsung 1333
1060 6gb twin cooler
*poor cable management
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
Yep, your airflow looks fine.
