Meshify C Air Flow
8 minutes ago, InsanityPC said:Hello, I have a few question about Air flow, more specifically how should I set up my air flow in the Meshify C? I want to use 4x120mm fans and 2x140mm, with the Corsair h115i Pro 280mm liquid cooler.
I want to go with one of corsairs RGB fans, not sure if I should go with HD or the LL series fans? i'l have to set some of them as intake and the back bracket will be showing.
I have attached 4 idea Sketches for Air flow below.
A: Always keep the PSU as intake and exhaust out the back where possible. It's generally better for your whole system.
B: Ignore the bottom intake/exhaust fan option. You have to remove the HDD cages to use it, and even if you do, it doesnt help much relative to how it pushes half the air into the bottom of the PSU shroud and will most likely have wires running all over the fan which is less of an "airflow concern" and more of a "wires near spinning blades" issues. Save it for a hard drive or extra cable management.
C: Rear fan should always be exhaust since it's un filtered. The top can be either intake or exhaust technically since it has a filter. That being said....
D:
Two 140mm intakes and a 120mm rear exhaust is generally the "optimal" configuration, as having too many intakes or too many exhausts have their own issues, and having more fans has diminishing airflow returns but a static increasing amount of noise.
The HD fans AFAIK only has LED's on the outer ring, the LL has LED's inside the fan hub.
