Hello everyone,
In my build I currently have an MSI GTX 1050 Gaming X Graphics Card and my CPU is an AMD A6-9500 Dual-Core at 3.5Ghz. When I got the graphics card and installed all the drivers, I was getting 60 fps in Fortnite at medium settings with a few settings a bit higher, but now I have had to put everything on low setting and I get stutters and hitches and my game will even crash which never used to happen. So I thought that I should maybe get a Ryzen 5 1500x so it should be able to remove the bottleneck on my Graphics Card and also so I can Record/Stream my games. So is a Ryzen going to help or will it only have minor improvements.
Thanks.
EDIT: My Motherboard is an Asus A320M-K
https://linustechtips.com/topic/920537-will-i-benefit-from-ryzen/
Nah your motherboard is a piece of **** first rule of Ryzen is don't get a 320 chipset.
Personal Desktop":
Luna, the temporary Desktop:
Just now, Spud11 said:
But will it still work?
Yes, but there's not much cost benefit of choosing an A320 board over a B350 board when B350 is way better.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
Will it perform the same as with a B350 board?
It should, as long as you don't want to overclock it at all.
Daily Driver:
Gaming PC:
1 hour ago, Spud11 said:
I wasn't planning on overclocking, will there be any performance decrease?
I don't think so.
54 minutes ago, Spud11 said:
Also will my gtx 1050 be bottlenecked or anything?
Nope. I'd recommend getting a Ryzen 5 1600 or 1400 though, for the best value.
Daily Driver:
Gaming PC:
14 hours ago, Spud11 said:
Thanks for clearing that up.
As was stated already, the cost savings of A320 are not worth it over a B350 motherboard. Support should be better as well.
Lappy: i7 8750H | GTX 1060 Max Q | 16Gb 2666Mhz RAM | 256Gb SSD | 1TB HDD | 1080p IPS panel @60Hz | Dell G5
