You have to upgrade both at once. The 100 and 200 series chipset boards aren't compatible with the 8000 series chips and vice versa the 6000 and 7000 series chips won't work on the 300 series boards.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/920533-motherboard-advice/#findComment-11280386
22 minutes ago, October22nd said:
So i currently have an i5 6500 @ 3.2Ghz and i want to upgrade to an i7 8700k. My motherboard currently is a Gigabyte H11OM-S2H would i have to or would it be more beneficial to upgrade the motherboard first. I am PC noob, if that wasn't clear already.
Check if your board has a coffee lake bios (some do, maybe you can get away with it) then you can use the old motherboard temporarily, otherwise you have to do both at once.
https://linustechtips.com/topic/920533-motherboard-advice/#findComment-11280466
Depending on your need you probably could go with a second hand i7 7700
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/920533-motherboard-advice/#findComment-11280496
