I got a new graphics card (rx 580) and got a new psu (500 watts) and is performing the same as my gtx 1050 on most of my games, (I will use Overwatch as an Example). In the start menu I get 60 fps, when I enter a game it drops to 20-30 fps some times 40 and when we start fight it goes to 7 to 15 fps, can someone help me here?
https://linustechtips.com/topic/920240-graphics-card-performance-help/
Rest of specs? Also what specific psu
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
did you install drivers properly?
you should DDU everything first before reinstalling the RX580 drivers
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Karamo
CPU: AMD Ryzen™ 5 3600 | CPU Cooler: Wraith Stealth | GPU: Gigabgyte AORUS GeForce RTX 2070 Super | Motherboard: MSI B450M Mortar Max | RAM: G.Skill FlareX 2x8GB 3200MHz CL16 | SSD: ADATA XPG SX6000 Pro M.2 256GB | HDD: 1TB 2.5" Western Digital Blue (WD10SPZX) | Case: NZXT H510 | OS: Windows 10 Pro 64-bit |
What PSU
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
4 minutes ago, Daniel Scharton said:
Amd Athlon X4 860k
gigabyte a68h
120 SSD
and a 250 SSD
8 GB of ddr3
And yes I installed my drivers and the rx 580 has 8 GBs
Your CPU could be bottlenecking. See if you can monitor CPU usage while gaming; if it's getting very high you might have a CPU bottleneck.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
That CPU is rather old and doesn't have very good IPC (pre-Zambezi AMD quad core.. eww).  I would look to try other games out or run a few synthetic GPU benchmarks, it's likely that the GPU is fine and the other older system components could be holding you back.
10 hours ago, Daniel Scharton said:
would 68% be bottlenecking
It shouldn't be. However, see if you can monitor individual core cpu usage. It's possible that one or two cores are at 100% whereas the others are only around 30 or 40
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
DDU in Safe mode and reinstall drivers fresh new as mentioned, make sure to delete all drivers (both amd and nvidia with DDU) and that CPU totally is holding it back.
CPU usage at 100% is just the easiest way to spot a bottleneck but the CPU can still be the bottleneck even without 100% usage.
Personal Desktop":
Luna, the temporary Desktop:
You don't even have to check this.
GPU performance is nearly the exact same after a significant GPU upgrade and your CPU is old, CPU bottleneck.
You would have to OC that thing to nearly 5ghz before you would notice a significant difference in game performance with any GPU.  Its performance is so bad that It was a holding even your old 1050's performance  back.
