what cpu is that?
Desktop benching:
https://linustechtips.com/topic/915505-help/#findComment-11232157
6 minutes ago, MelonManMan said:
there is A ryzen 5 2400g, gigabyte gaming ab350 3,ddr4 vulcan ram seasonic 520 watt PSU in it
I would highly suggest returning that motherboard and getting an ASrock Pro 4, it at least has heatsinks on both VRMs
The iGPU has to pull it's power from the SOC VRM on top of the board, and since it has no heat sinks it's likely going to get very very hot.
Assuming all the power is plugged in, and the power switch is on the power switch header you should be alright, try rebuilding it maybe.
https://linustechtips.com/topic/915505-help/#findComment-11232195
This will sound dumb, but is your PSU on?
That has happened to me too many times to count.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
https://linustechtips.com/topic/915505-help/#findComment-11232209
1 minute ago, MelonManMan said:
yes, i have also tried turning it off and on again.
Take out all the PSU connectors and do a paper clip test to see if the PSU is working.
https://linustechtips.com/topic/915505-help/#findComment-11232232
Just now, MelonManMan said:
so i jumped it and the case fans plus the drives turned on
Then maybe something on the motherboard isn't hooked up right, but I would seriously monitor your VRM temps once you get it up and running.
https://linustechtips.com/topic/915505-help/#findComment-11232253
i got the pc to turn on, but now the monitor is not getting signal(i know the monitor works, used it as second screen for a laptop)
https://linustechtips.com/topic/915505-help/#findComment-11232270
