What does this mean and how do I fix it?
Tmh85
So my computer just randomly crashed so I ran Who Crashed and it came up with this
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Sun 12/8/2013 8:47:04 PM GMT your computer crashed
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x9F (0x4, 0x12C, 0xFFFFFA800C016540, 0xFFFFF80062119790)
Error: DRIVER_POWER_STATE_FAILURE
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
What does this mean and how can I fix it?
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
First and foremost, You need to update your drivers.
Also boot into your Windows Disk, hit repair, Advanced Options, Command Prompt
OR
In windows, open CMD as an Administrator
And do a system file check (type in sfc /SCANNOW)
Also recommend to give the system a good clean up (malware, programs, etc)
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
If that has come only once and you haven't had any issues before and after it, then just ignore it. I had that also last week. Or week before. No problems after it. It just means that drivers have crashed.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
