will PCI-E samsung 960 affect my gpu ?
Solved by DocSwag,
10 hours ago, samir haddad said:so if i put NVMe it wont affect any performance of the gpu at all ?
and the gpu will use all the 16x lanes?
because i entered asus motherboard and read about this ..
it look like the new 370z chip have a mini cpu that have saperate lanes for this kind of things , is that true?
page 4
Depends on what ports. Unless you use a pcie to m.2 adapter though it'll probably use chipset lanes and won't affect the gpu.
