ryzen Ryzen 5 1600 OC | Ideal Cooler and Suggestions
2 minutes ago, tmph.Gammatron said:Thanks! I'll try that later. I wasn't sure why i set the Oc to 3.4, but someone already corrected me with this. hopefully i can oc it without making my PC a toaster
Will you get another cooler for your chip?
I have now changed PCs with my wife, and I set it back to stock for her. But long as you have good air flow in your case you could run 3.8 easy on stock cooler.
If you are able to go higher I would suggest a aftermarket cooler. I like the Cryorig range of coolers, the cooler depends on the case clearance. My Ryzen is in a InWin 303 case and can only fit a 160mm tall cooler so 212 or Cryorig H7 would do the trick.
There is a hand full of videos on youtube on how to overclock, thats what i watched to get all the correct settings for the R5 1600
