I am having a WD Green 120GB Internal Solid State Drive (WDS120G1G0A)
I bought it from amazon well the read speed on sata 2 if fine (around 250mbps)
but the write speed is very low when I run Blackmagic disk speed test the write starts from 150 and goes . down constantly to 60 - 70
Please tell me what to do?
Is the product defective ?
It was shipped on 21st March 2018 (this month) and is almost empty.
https://linustechtips.com/topic/909027-read-write/
Keep in mind, the advertised speeds are sequential read/writes.
It will be lower with random read/writes.
Depending on the block size, that is around right:
http://www.hardwaresecrets.com/wd-green-120-gib-ssd-review/4/
http://ssd.userbenchmark.com/SpeedTest/201586/WDC-WDS120G1G0A-00SS50
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/909027-read-write/#findComment-11169768
1 minute ago, anshu2002 said:
@-rascal-
First of all thanks for your concern
But don't you think that 90mbps for an SSD is pretty slow.
and I am using the the same programme for test then why a huge difference?
often then the speed you see listed in benchmarks is for burst into the slc cache. Once you fill up the cache that is a normal speed. Also smaller drives will be slower, so this seems fine here.
https://linustechtips.com/topic/909027-read-write/#findComment-11169851
Try crystaldiskmark instead?
https://linustechtips.com/topic/909027-read-write/#findComment-11169861
