so this is my first time setting up a server, and my client needs it to input/store a really sensitive data. I don't have that much knowledge about server, and I really need the help of you guys.
so, I haven't decided whether to go i7 + Z Mobo or a Xeon + Server board (E3-1245v6 + S1200SPLR), I'm planning to use 2TB of HDD x2 running RAID 1, also a 120Gb SSD for system, and using FreeNAS.
I'm really confused about what to do and what to use, can you guys suggest a setup that won't cost over $1100 ?
He also mentions that he wanted the server can also be used as an admin pc (not just a storage server), is this possible ?
https://linustechtips.com/topic/909011-building-a-nasserver/
What applications do you want to run? What OS?  What do you want FreeNAS for and how are the storage needs going to look a few years from now?  If this is meant as a reliable NAS system in production use where money is on the line then I'd recommend a dedicated NAS, think Synology/QNAP/Netgear, if it's meant as a project for fun, to learn from and as a hobby then build something yourself.
Anyway, it's hard to give a good recommendation without more information. The platforms you're suggesting (i7 or E3-1245 v6) are pretty CPU heavy, something I wouldn't expect from a storage box?
PC: i7-6700k, GTX 1070, 32GB DDR4, 256GB NVMe, 1TB SSD, 2x U2715H
VM Server (Proxmox): E5-1650v3, 64GB DDR4, 128GB NVMe, 1TB SSD, Intel X540-T2 10GbE
NAS: 2x Synology DS1817+, 16x 8TB Seagate IronWolf, 2x Intel X540-T1 10GbE
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169652
Only 2tb? and most of them are still 64mb cache...toss between to me been looking at is those 4tb Barracuda's or the Toshiba x300...both are 128mb cache...blow the socks off my older wd blue...no comparison.  Or yeah some of the NAS stuff. and yeah definitely Z gonna have 3 of them again here shortly. Need an upgrade of service lol
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169676
I don't know the circumstances behind it but did you tell your client you could build them a server before admitting to this forum that you've never built a server? Not a good idea.
By default FreeNAS only uses AES-128 bit encryption on the disks which if using RAID1 (the complete data is on one disk) then a decent computer could brute force that in not a significant amount of time. I don't know if it's possible to increase the encryption level (though it ought to be) but it'd make it fairly easy to steal the data if either disk got stolen or thrown away.
Hardware wise I can say if it's in the budget you'll want a Xeon with an appropriate server motherboard and ECC RAM. Any ATX PSU will do for this kind of setup but find one that is at least 80 Plus rated. You want to know it's getting fed correctly. EVGA & Corsair make good PSUs I lean more towards Corsair but that's just my preference.
Boot drive, FreeNAS can run off a USB. Just install it to a flash drive and set the boot device to it.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169692
When picking drives for my server I ran into this issue. I wanted 128MB of cache in a "low capacity" (2TB) drive. It took some searching but I found some. Very happy with them.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169697
yeah if I could find a 2tb like that wouldn't mind that. You can fill up just a tb anymore quick between gaming and whatever else media junk.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169719
I still haven't decided, what do you suggest ?, I want to use FreeNAS to organize the storage and accessibility for multiple users at the same time.
I don't think 2TB x2 is not enough, so I'm going to change it to 3/4 TB x2 RAID 1, is that enough ?.
I've been thinking about buying a pre-built NAS like Synology, etc. But, I kinda wanted to have experience for myself to build a server by my own hand.
Is it too overpowered for a storage box ?, if it is so, I can change the processor and the mobo, and assign more money to HDD.
any suggestions for the server rig setup ?
Currently having budget of $1100 - $1300.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169784
Yea, i'm going to change it to 3/4 TB x2 RAID 1
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169786
2
Yea, I know it is not a good idea, but it already happened, so...
My setup currently goes like this :
Xeon E3-1245v6
Intel Server Board S1200SPLR
Samsung 120GB SSD
2x 3/4 TB  (Seagate or WDC) RAID 1
V-Gen DDR4 8GB ECC Memory
An EVGA 500W PSU or Seasonic
Perhaps you can suggest another server setup for me ? that will be so much appreciated.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169795
Xeon E3-1245v6
Samsung 120GB SSD
Get the Barracuda's only like a 100$ each.  X300 is a little more but might be worth it..probably built better.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11169848
Seagate IronWolf Pro ST4000NE0025 - $183.99 x 2
CORSAIR RMx Series RM550X - $99.99
SUPERMICRO MBD-X11SAE-O - $192.99
Intel Xeon E3-1245 V6 - $309.99
Noctua NH-D9L - $54.90
Kingston ValueRAM 8GB - $107.98
Mushkin Enhanced atom 8GB - $11.72
Total: ~$1,145.55
I've heard good things about the Seagate Ironwolf Pro's so you might as well give them a shot. 128MB cache, 7200RPM, and 4TB.
The PSU isn't anything special, should be more than enough power for the purpose and more drives in the future if desired.
Supermicro is pretty much a standard for servers. A lot of features. Room for expansion, etc.
The CPU you picked seems the most bang for the buck deal so I kept it.
The Cooler is compact and should keep the CPU VERY cool regardless of system load.
The RAM isn't very special. For your clients needs 8GB is enough but the motherboard will support up to 64GB
The USB isn't special. Just install FreeNAS to it and plug it in. It's your boot drive.
Issues you may encounter is if the motherboards BIOS isn't new enough for the CPU. In which case you'll need to locate an older chip. i3's, Pentiums, and Celerons, are options. Basically any cheap chip just to update the BIOS so you can use the new chip. It cannot be said if you'll get a board with an up to date BIOS. Just know this can happen.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11172095
Total: ~$1,145.55
Alright, thanks for the suggestion bruh,
but he also wanted the server to also be some kind of workstation, so he can also use it to input data, Is this possible ?
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11172404
The only thing I can think of is if you ran ESXi or UnRAID. To my knowledge ESXi costs money. UnRAID...I think it's open source. It could host the file share and run a VM for the workstation. FreeNAS supports the use of VMs but they don't run like butter and they don't support hardware pass-through like for GPU acceleration. ESXi and I believe UnRAID can do this but I have no experience with either.
Your client is definitely better off having a dedicated server and dedicated workstation. Honestly combining the two makes no sense considering the nature of what a file server is.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11172527
Do your client already have a solution for backup? I guess he don't want to lose his "sensitive" data?
If you isn't going to use ECC-memory, just get a cheap Pentium och i3, it's more than enough for a storage server. Better to put some $ on a UPS to protect against surges and data corruption.
Don't mix server and workstation, the client should not use the same system, for anything else, apart for virtualization of a system accessible from another computer.
Otherwise you just could put a bunch of disk in a regular PC that he use and host the files from the same system via simple file sharing if the files needs to be accessible for multiple users or from several systems.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11174009
UnRAID cost money, ESXI is free up to 8 CPUs.
I would go with FreeNAS or a simple off the shelf system for the same price. Considering you haven't ever build a system before, you are really deep in if you screw up.
Personally i'd suggest you download and install FreeNAS on another system and learning the group policies and how to set it up properly before getting it up at the customers location. Also find out if the network you are setting it up for are in DMZ host or have open ports, all this causes security risks that you will be held responsible for if something goes wrong.
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11178626
"Don't get ECC RAM, but protect against data corrpution"?
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/909011-building-a-nasserver/#findComment-11179003
