So I'm at a loss for what I'm doing wrong here. If I set plex to automatically configure a port it successfully establishes a connection for about an hour and then magically looses it so I decided to manually set up a port..... with no luck I might add. Do I need to set up a Dynamic DNS? I'll include some screenshots.
Server has a static IP also
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/908325-port-forwarding-not-working/
Have you rebooted your router after applying those port forwards? I've some funky, truly unexplainable issues with port forwarding like that with my netgear R7500 router.
EDIT: Also, have you tried not mix-matching the ports, like just make both LAN and WAN port 32400?
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
No I haven't restarted but applied the settings which kinda performs a soft reboot.
Yes I did try making them both the same, still didn't work.
| F@H STATS |
Just now, MajesticDoughnut said:
I had the same issue for a long while. Updating the firmware on my firewall fixed it once a new one came out.
I run an ISP modem right now :(((
| F@H STATS |
Thats the problem. My friend uses a Comcast modem/router, it wont port forward worth a shit. You might need to contact your ISP can see if they can do it for you. Because they have access to your modem/router and can access any setting.
I have access to all the settings too lol
| F@H STATS |
Yeah, but they have access to all settings. Some ISP's make it so the user cant change certain things so they dont break shit. Plus you dont have access to all settings, some are hidden. This is part of the reason I dont use ISP supplied boxes, I prefer to buy my own, because at the end of the day, they not only have access to the settings, but know every device connected.
This is a telus modem.
They have a ton of features and allow you to port forward perfectly.
I have been running multiple servers from home for the past 8 years.
Well my friend has been using a Comcast modem for years, and it wont port forward worth a shit. Its no an isolated issue, Ive seen others with the problem. Also Comcast is known for putting broken shit back in to service. Which is another reason I dont use a Comcast modem, because I anit paying $10 a month for some broken ass shit.
Ok but this is a telus modem.
OP's issue is something else.
No idea why he's using plex, he should be using a different port for manually port forwarding not 32400.
Are you sure you got all the settings correct and nothing has changed?
Has the internal IP if the server changed?
Has your external IP changed?
Does the server listen to the correct internal port number?
Does the remote connection use the correct external port number?
Do you have any other device between the connections that may interfere with the ports? For example another router at home, or a firewall at the remote place?
OP says hes in the US. Telus is not a US company.
You're right, it must be a company that uses the exact same modem then huh
