Hi all
Here is my code
for i in range(0, 5):
  if i == 3:
    # here i want to change i to another number
    print(i)
  else:
    print(i)
I know it sounds useless but this is as simple as I could get it for a bigger program
How can I change the var i in the for loop?
If I type on line 3
i = 5
it will say that i is undefined because it is only a local variable
So how can I change the var i in the for loop?
Edited by Hugs12343
Error in code
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/907537-python-for-loop-help/
4 minutes ago, Hugs12343 said:
Just define "i" before the for loop? like i = 0?
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11154934
Tried that doesn't work
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11154937
I'm not sure what you are doing, but that code should work if you fix the missing semicolon at the end of the first line.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11154940
There's no semicolon. It's python
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11154945
Err, colon I meant:
  if i == 3:
    i = 5
    print(i)
  else:
    print(i)
Works just fine. Are you by chance trying to access i somewhere else? The exact error message would be useful.
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11154949
5 minutes ago, tikker said:
Err, colon I meant:
  if i == 3:
    i = 5
    print(i)
  else:
    print(i)
Works just fine.
can confirm.
EDIT: however, the value of i does not carry over outside the if statement
EDIT/EDIT: thats the purpose of a for loop isnt it? disregard..
what this does:
first round i = 0 => else, prints 0
second round i=1 => else, prints 1
third round, i=2 => else, prints 2
fourth round, i=3 => if, prints 5
fifth round, i=4 => prints 4
loop done.
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11154951
49 minutes ago, Hugs12343 said:
Hi all
Here is my code
  if i == 3:
    print(i)
  else:
    print(i)
If I type on line 3
i = 5
class u():
    i = range(0,5)
for i in u.i:
    if(i == 3):
        i = 7
        print(i)
    else:
        print(i)
This works it and all you had to do is put variable i in a class to make it where you could change it.
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11155070
3 hours ago, Hotseff said:
class u():
    i = range(0,5)
for i in u.i:
    if(i == 3):
        i = 7
        print(i)
    else:
        print(i)
I tried this. but it doesn't change the variable i in the for loop.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11155647
Try this:
6 hours ago, tikker said:
Err, colon I meant:
  if i == 3:
    i = 5
    print(i)
  else:
    print(i)
ENCRYPTION IS NOT A CRIME
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11155859
What is the bigger problem maybe we can help with that.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11156094
What is it that you are trying to change about it?
Let me elaborate on my earlier snippet. I've removed the redundant double print statemement. Take a look at this example (code below as well): https://repl.it/repls/BleakGrizzledPolygon
#Show the values that will be iterated over. list(...) is needed since in Python3 range is a generator, like  xrange in Python2.
i = list(range(0, 5))
print(i)
# Loop over them.
  print('Iteration ', i)
  if i == 3:
    # Change i to hold the value 5 temporarily.
    i = 5
    print('The value of i will now be', i, 'for the rest of the loop.')
  print('The value of i is', i, '\n')
The range function will, as its name implies, generate a range of numbers between a given start and end. By definition the value i will take the next value in the range at the start of each iteration. Once you assign a new value to it, it will keep that value for the rest of the loop, or until it is changed again. Once the next iteration starts however, i will be (re)set to its intended value: the next one in the range.
This may help us give more concrete help.
https://linustechtips.com/topic/907537-python-for-loop-help/#findComment-11157418
