my dad has logitech z4 wich are awesome you can put the bass verry deep so that every thing vibrates
he bought them for 80 euro and i would love the same set but i can't find them annywhere or for 200 euros :(
So i would like a same audio quality for around max 80 euros but cheaper is always better
i dont know if it matters but i use onboard audio
thank you in advance
P.S. sorry for possible bad english it's not my first language :)
https://linustechtips.com/topic/90622-deep-base-speakers/
First off its bass not base. Second the Logitech speakers are generally not great when it comes ti sound quality.
https://linustechtips.com/topic/90622-deep-base-speakers/#findComment-1224442
It's to not ti
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/90622-deep-base-speakers/#findComment-1224454
Those logitechs, like most pc speakers are all bass and treble with no SQ to speak of and, well all the ones I've heard I have never been impressed with the bass performance.  I certainle would pay more than $30 bucks for speakers like that.
I would pay $200 for a decent stereo amp and hifi speakers with 12" woofers. That will give a good bass and superior SQ as well.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/90622-deep-base-speakers/#findComment-1224819
The bass on these boxed sets is impressive if you've never heard a real subwoofer and only listen to the earbuds that come with your phone. Most don't even go all the way down to 20Hz.
https://linustechtips.com/topic/90622-deep-base-speakers/#findComment-1225013
