Help me decide - 12, 14 or 16mm borosilicate glass tubing
On 3/12/2018 at 4:29 PM, Damascus said:Im rebuilding my loop with glass, I'm moving away from 3/8" 5/8" soft tube, a diameter that I quite like. Looking for some input before I buy my tube and fittings
12mm is tiny and looks ridiculous at times in certain cases. 13mm is the next size but only made by AlphaCool, it also forces you into only using AlphaCool fittings, 13mm is still kind of small. 14mm Unless you get tubing from a glass shop, I haven't seen any waterCool company make this size. Finally 16mm which in my opinion is the best size. Which also allows you to use any metric made fittings. Since almost every company makes 16mm fittings.
Mayhem's Glass is better then AlphaCool Produced Glass tubing. I suggest using Mayhem if you can over AlphaCool.
I use 16mm Glass tubing in my own build.
Next make sure you know how to cut glass, how to edge the sides so not to tear the o-Ring when it's being inserted. Finally but most importantly you have all proper safety gear. Glass dust can kill if it's inhaled.
