Dear Team,
My current pc configurations is -
Gigabyte Mobo
i5 6500k processor
8 gb ddr4 ram
Sapphire r9 390 nitro gfx card (Too long size)
h60 corsair cpu cooler
Corsair spec 03 cabinet.
My gfx card is too long and airflow is also not good with my cabinet, kindly suggest me a good cabinet which will fit my sapphire r9 390 nitro card, and for best airflow and cooling .
I was planning for s340 elite , but users are saying it is only for good looks and not that preferred for cooling and airflow, what else cabinets do you guys suggest ?
I am from India ... and temperatures here are always high...
https://linustechtips.com/topic/904559-need-a-cabinet-for-cooling/
Hello from America to India!
And here we call it a case, rather than cabinet.
(not sure if removing the 0 response on your thread was worth it)
edit: first case that popped into my head https://www.newegg.com/Product/Product.aspx?Item=N82E16811352072
Audio go Brrrrrr
We call it cabinet ... :P:D
Will the meshify c fit my sapphire r9 390 card without removing its HDD bays .
And i also have h700i in my mind... what do u think
GPU Length: 308MM
Case max GPU length: 315mm with front mounted fan included
So, yes wit will work, just barely. The HDD cages are locatd below the PSU shroud, so theres no worries about the HDD bays getting in the way.
H700i is very expensive, especilly given the rest of your system.
Fractal Design also has the Focus G which is a slightly larger and cheaper Meshify C without the glass. https://www.amazon.in/dp/B071SHFRTP/?tag=pcp03-21
