How does setting the Compression flag for drives affect read/write speed?
NTFS compression is lossless so quality is not afected. However performance is. CPU resources are required to compress and uncompress the data. It is also of questionable benefit.
SSD compress data to save space. The saved space is not reported as available to the system. Rather it is used to improve wear leveling on the drive. Using NTFS compression means more can be stored on the drive. But at the cost of less space available to extend life of the drive.
But this behavior may explain the variable performance you noted. When data is compressed by the o/s the SSD cannot compress it any further and so has to write the entire amount. If an o/s uncompressed block is written, the SSD can compress then write it. Because the SSD compressed the block, the write may be faster (less to write).
