Blue Yeti making wind noise
Joonass
Soo, I have a Blue Yeti microphone. It has worked for about 3 months. Suddenly today I started my computer and the microphone wasn't working right, it made wind noises. I checked the cable it was connected, tried it on other computers and nothing seems to work. What could the problem be?
do you have a something like a dead kitten
or something similar to block out wind and background noise ?
It may also have something to do with the cables not in all the way, because it if a cable isn't in all the way, it sometime will make noise similar to a light bulb hum.
Edit* if the mic fell over or was bumped or something, it could have  broken the ribbon, condenser etc making it not work so it doesn't pick up vibrations anymore, but this is really unlikely.
Edited by Eduard the weeb
Ex frequent user here, still check in here occasionally. I stopped being a weeb in 2018 lol
For a reply please quote or  @Eduard the weeb me :D
Xayah Main in Lol, trying to learn Drums and guitar. Know how to film do photography, can do basic video editing
This should most likely fix the problem. Mics are like speakers, they suddenly just dont quit working. You have to do a lot to mess up a Mic or Speaker.
System
  • CPU
    Ryzen 7 5800x
  • Motherboard
    Asus ROG Strix B550
  • RAM
    Corsair Vengeance Pro RGB 3200MHz 32GB (16x2)
  • GPU
    EVGA Nvidia RTX 2080TI
  • Case
    Fractal Design Define R5
  • Storage
    WD Black SN750 500GB NVMe SSD | WD Green 2TB HD | WD Green 3TB
  • PSU
    EVGA Supernova 850W
  • Display(s)
    Asus 1920x1080p 144hz
  • Cooling
    Cooler Master Master Liquid 240
  • Keyboard
    Logitech Pro TKL
  • Mouse
    Logitech G502
  • Sound
    Logitech G733
  • Operating System
    Windows 10 Pro 64 Bit
Tried everything did not work. The mic picks up voice but it picks the wind noise too.
its most likely just needing something to block it out, It may also needed to be adjusted in settings if there are any so you turn down sensitivity of the mic, so it picks up less noise.
You can make a DIY Dead cat with a coat hangar, and a thin sock if you put the sock on it and bend the coat hangar to cover the mic.
