Tiny Screw Stuck In Motherboard Standoff
Solved by Tsuki,
its not a screw, its supposed to be there. dont try to remove it.
its the center pin for the motherboard, it holds it in place so that you can screw it in everywhere else
Featured Topics
Od1sseas ·
Posted in Operating Systems1 -
amaliasugar ·
Posted in Graphics Cards0 -
2
Louscou ·
Posted in Troubleshooting2 -
1
nulcow ·
Posted in Laptops and Pre-Built Systems2 -
2
1
SteffanF ·
Posted in New Builds and Planning3 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
