1 minute ago, Cupar19 said:
So i have about £100-£150 and wanted to decorate my gaming area with some tech related things but didnt really know what, any ideas?
thanks
I think the motherboard wall Linus has in his office is pretty cool. Theoretically you could probably score some mobos for free from your local ewaste place (since they have to pay to get rid of them usually)
Maybe some paint and screws/ etc and your set
https://linustechtips.com/topic/898482-tech-decorating-ideas/#findComment-11065855
was thinking something like that, or maybe doing something with ram or cpus. but the only problem is where i live there isnt even a tech shop let alone a ewatse center so i would have to buy them on places like ebay where they are quite expensive
https://linustechtips.com/topic/898482-tech-decorating-ideas/#findComment-11065863
You could setup some RGB strips behind your monitors to add some extra effect if you like rgb
Maybe something's cool down here?
System specs are in profile
Just an average guy looking around the forums for something intresting...
Enjoy your memes. ^_^
https://linustechtips.com/topic/898482-tech-decorating-ideas/#findComment-11065919
