i want a high airflow case allot new case care more in looks.
I found only one i like and you can move the power supply to it self as it removes that hot air in the case to other side with there own holes and if you did water cooling it wont touch the power supply and no dvd drives or cages all are in back with the cables i dont see many simlart case?
is corsiar the only one who did this and will i get good airflow if the power supply not in front of the cpu and gpu?
5a8077875971e_air740watercooled.thumb.png.adffed80cecb3ffd7361a1808bf6ae1b.pngair740 front motherboard.jpg
https://linustechtips.com/topic/895424-case-high-airflow-build/
I beleve maybe ur looking for "cube" cases then.
Lian-Li do a few, so does Thermaltake. Take a look at those.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/895424-case-high-airflow-build/#findComment-11033592
do they remove the power supply to the back too like the corsair one and  a atx motherboards
https://linustechtips.com/topic/895424-case-high-airflow-build/#findComment-11033625
Yes. Lian Li has a few, PCO8, PCO9, PCO10, PCO11
Thermaltake has their Core X5, which puts the PSU underneath the case (it has a different layout, but the concept of keeping the PSU separate from the rest of the build is the same)
https://linustechtips.com/topic/895424-case-high-airflow-build/#findComment-11036309
allot of them are fashion and looks only glass with no holes in front like corsair to let high airflow with out water cooling
https://linustechtips.com/topic/895424-case-high-airflow-build/#findComment-11044973
The vents are along the side or bottom, not the front. It's a bit different than traditional designs. They are definitely "Fashion and looks" and do sacrifice some performance. The 740 will cool better especially if you're not watercooling
https://linustechtips.com/topic/895424-case-high-airflow-build/#findComment-11045091
i want both air and water cooler as looks you can make anything look good but having better airflow matter more than looks
https://linustechtips.com/topic/895424-case-high-airflow-build/#findComment-11048820
I would definitely stick with the Air 740 or Air 540 then :)
https://linustechtips.com/topic/895424-case-high-airflow-build/#findComment-11048825
