(FIXED) Pc Ethernet Slower than wireless!!
I have my router connected to my Pc with a cat 5e cable. A speed test on my phone shows 280 and 14 upload on 5G. Same with my laptop but my desktop is always 60 and 2.5 upload. The lan port supports up to 1gig on my mobo. Can not find out why?
MSI b350m gaming pro
Ryzen 3 1200
8GB 2400mhz
500w evga
GTX 10603gb
Windows 10 pro
https://linustechtips.com/topic/893366-fixed-pc-ethernet-slower-than-wireless/
Ryzen 3 1200
8GB 2400mhz
500w evga
GTX 10603gb
Windows 10 pro
im sorry... what??
youre running speednet off your phone... same with your laptop?...then your desktop is 60 down, 2.5 up?.....
what seems to be the question here
7 hours ago, Lxfts said:
Yea Speed test on phone is 280 download and 14 upload. Speed test on pc is 60 down 2.5 up Why is it so much slower and its wired
There is still too much confusion as the title is about wifi slowness yet you say your PC is wired.
4 hours ago, Lxfts said:
Yes, My pc is wired but the speed is much slower and I am trying to found out why.
Hmm, so what is your network layout?
You have a main router (What model)? Is the PC directly plugged into the router? How far away is the PC from the router?
Have you tried a different Ethernet cable?
I'm not really an expert on this wireless stuff but I think 5G and wifi are different things correct me if I'm wrong please
your mobile and laptop are connected to the same router as your computer?
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
cisco dpc3941t
Pc is ethernet my laptop and phone are wireless but the pc internet speed is much slower
1 hour ago, Lxfts said:
cisco dpc3941t
Ah, I've seen this router before. My uncle has this same model. It does have 1Gb/s Ethernet ports. Still strange as to why the speed difference.
On your PC, did you check the network adapter properties to make sure it's running 1Gb/s mode?
Also, what are you using to test the speed? Same website for all three devices?
Finally, you have installed the Ethernet driver for the PC's motherboard right?
Yep went to msi's website. Its set to 1gig on the adaptor. using xfinity.speedtest and speedtest .net
hmm, running out of ideas now.
Does your laptop have a Ethernet port? What happens if you plug the laptop into the Ethernet port on the router? Same speed as the desktop?
5G in WiFi refers to 5 Ghz, which can support much faster speeds on the WiFI standard compared to the standard 2.4 Ghz band.
1 minute ago, Lxfts said:
My pc is ethernet
If you actually paid attention to who I quoted, you would have seen I was answering @aezakmi question concerning the 5G reference. As they though people were talking about 5G Cellular data, and not 5Ghz WiFi.
asked because I stumbled upon some articles about a 5G network that's for phones but nvm
https://www.wsj.com/articles/sprint-to-launch-5g-network-in-2019-1517590579
OP's problem is a weird one, @Lxfts have you tried using a wifi receiver on your desktop computer?
Nope dont have one
Got my old laptop plugged it in. It got the same download speed on my desktop but the upload was 11 on the laptop like my phone but still my desktop got 2
Man, this is very weird indeed. The ping is lower on the Ethernet at least.
I still don't understand why the wired part of the router would be slower though.
very likely the cell phone will try to use its internet as well as your isp landline internet
but watch linus video on cat cables and their frequencys used(100mhz 200mhz 250mhz)
cat5 works with 1gbps but it does not share well as its 100mhz cable(it takes ages to talk)
open youtube video then goto settings and play speed
treat normal speed as 1gbps 200mhz
now set video to .5x playspeed
this is how router sees the slower freq cable
try setting your adapter to halfduplex and it should behaive better as this will force the adapter to do either send or recieve but not both simultaneously
did you turn your cell data off to due the test?
Does your pc have built in ethernet or are you using a usb to Ethernet adapter?
can you confirm the link speed from the router to your pc? there may be a page in the router saying port X is connected to 1gbps
Yes data was off. Im using the lan port on my pc. Router is cisco dpc3941t
