Posted February 5, 2018 I bought the define r6 without the windowed side panel and i want to know if there is somewhere i can just buy the windowed side panel Main PC (The Silencer): CPU - i5 8400 | Cooler - Noctua ND-D15 | Motherboard - Asus tuf Z370 Plus Gaming | Memory - Team Dark 16GB DDR4 2400MHz | Graphics card - Nvidia 750 ti | Storage - Crucial MX500 500GB, WD Blue 2TB | Case - Fractal Design Define R6 | PSU - Evga Supernova 650W 80+ Platinum Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 5, 2018 8 minutes ago, Zeta_Demon said: I bought the define r6 without the windowed side panel and i want to know if there is somewhere i can just buy the windowed side panel Contact Fractal's customer support, they might be able to hook you up. I know they have the Define R5 windowed side panel listed on their site. They may be able to sell you the R6 window. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 5, 2018 I've brought a side panel for my R5 from Pudget System before. See if they have it listed on their spare part store page. If not, contact Pudget or Fractal. PC Build: Project Re-Define | Project Mochii | Personal Rig v3 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 8, 2018 @Fractal Design NA on their contact page should have a good solution for you. I would try there first. Midnight Rig - CPU: i7-7700K / Cooler: Corsair h100i V2 / Motherboard: AsRock Z270 Taichi / RAM: G.Skill TridentZ 3200Mhz / GPU: EVGA GTX 1070 FTW2 / SSD: Crucial MX300 525GB / HDD: Seagate Barracuda 2TB 7200rpm / PSU: EVGA Supernova B2 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
