best bet would be buying some rig used with a 750ti or sth. like that. Otherwise, maybe the apus that launch soon will allow you to get sth this dirt cheap. but apart from that, you really need to save more to get sth worth it
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/892944-best-pc-components/#findComment-11007828
windows is gonna be where it hurts most if you dont buy a prebuilt, so I agree with 19_blackie_73
Ryzen 5 1600x | Asus ROG Strix B350-f gaming | 16 GB Trident Z RGB RAM | Asus ROG Strix 1080 Gaming X | Hyper 212 Evo | 650 W 80+ Gold | 500GB 860 evo | 500 GB WD Blue HDD | Phanteks Enthoo Pro M Tempered glass.
https://linustechtips.com/topic/892944-best-pc-components/#findComment-11007861
Heres a decent one, $350 bucks really isnt a lot but heres an example of what you can get https://pcpartpicker.com/list/Q3DBgL
https://linustechtips.com/topic/892944-best-pc-components/#findComment-11007879
Budget in euros? You'll wanna get something used.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/892944-best-pc-components/#findComment-11007926
32 minutes ago, QuintJustus said:
So a friend of mine asked if i could build a pc for him under 350 bucks (he Lives in germany) he wants to play games such as cs go and wow on high with 60fps
Can you guys help me storting the components?
Wait for the $99 USD APU see this thread for a basic parts list/info
You can just download windows 10 for free anyways
https://linustechtips.com/topic/892944-best-pc-components/#findComment-11007966
