low performance with ryzen 5 in CSGO
dotz
There's probably a million other posts like this but I just can't find a solution online, so here I am.
System Specs:
Windows 10 Pro 64bit
CPU: Ryzen 5 1400 ----- *overclocked to 3.5GHz
GPU: EVGA GTX 1060 3GB GAMING ACX 2.0
RAM: CORSAIR Vengeance LPX 1x8GB DDR4 2400MHz ----- *overclocked to 2666MHz
MOBO: BIOSTAR Z270GTN *EDIT* X370GTN
PSU: Silverstone SX-500LG
SSD: Adata SP900 480GB
I'd say this is a pretty current gen and mid range system, so it should crush csgo at 1080p-high settings. Other people I've seen online with very similar specs run above 180fps even without the overclock, yet I can barely manage around 100-120. This seems to be a CPU bottleneck because I get much lower fps in deathwatches where presumably player spawns overwhelm my CPU, which shouldn't even happen with a ryzen 1400. I have a damn near brand new install of windows, and I have tried all the fixes people post online, unparking CPU cores, deleting config file, changing launch options, changing windows power settings, etc... I really can't tell what's wrong, somebody please help me...:(
Use some form of hardware monitor, like afterburner, and see what your GPU vs CPU utilisation is during gaming.
If your cpu is pegged at ~100%, while your gpu is at 60% (or whatever) then you can confirm your cpu is the bottleneck. otherwise it may just be down to settings
That's impossible I'm afraid ;) Ryzen chips don't work on Intel motherboards.
Like @Hugsy Malone mentioned, run some monitoring during gameplay. If the GPU is at or near 100% and your CPU isn't it's not a CPU bottleneck.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
What is your CPU usage when playing?
Isnt that RAM Dual Channel? (You need 2 sticks to run at desired speed)
Mobo MSI X370 Carbon CPU Ryzen 7 1700 3.8GHz RAM Corsair Vengeance RGB 2x8GB 3000MHz GPU ASUS GTX 1070 Strix Case NZXT S340 Storage Samsung 960 EVO 250GB M.2 - Seagate 1TB  PSU EVGA 750W Cooling NZXT Kraken X52 OS WIndows 10 Pro
Keyboard Arachnid Recore - Cherry MX Red Mouse Corsair M45  !!--GTA V--!!
What was the performance like before the overclock?
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
His motherboard is most likely the X370GTN mini-itx by Biostar.
Anyway, is multi-core rendering enabled in CSGO settings?
How much CPU and GPU usage do you get?
I get 100% GPU usage at ~300 fps with lowish settings in CSGO, and the 1060 3GB is slightly worse than what I have, so consider lowering some graphics if the GPU is maxed out.
CPU: Ryzen 7 5800X Cooler: Corsair H100i Platinum SE Mobo: Asus B550-A GPU: EVGA RTX 2070 XC RAM: G.Skill Trident Z RGB 3200MHz 16CL 4x8GB (DDR4) SSD0: Crucial MX300 525GB SSD1: Samsung QVO 1TB PSU: NZXT C650 Case: Corsair 4000D Airflow Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
check to see if multicore rendering is enabled in settings. If it doesn't fix the problem, reinstall. I used to only get 120fps (i5 7300 & 1060 6gb) until i reinstalled the game. Now on most maps i get 160-200 fps
I usually get 200 fps on my system with an r9 270x 4gb and ryzen 1700x. It seems a bit low compared to all the other cards here.
http://pcpartpicker.com/list/Mf3Zcc My build
R.I.P Donny- Got banned. We will always remember your spamming of "Cancerbooks"
iPhones are like 1 ply toliet paper with a logo slapped on them and years old hardware in them- A Wise Man
Thanks for all the replies y'all, happy to see how many people on the internet are here to help.
Anyways, let me address all the responses:
1. yes I got that motherboard name wrong (somehow)
2. I'm running single channel RAM
3. I think the performance was slightly worse before the overclock, can't be sure...
4. Multicore rendering is enable, and I'll try to reinstall csgo if all else fails.
5. Here are the numbers of a bunch of benchmarks I just ran:
Cinebench score: 679cb
CS:GO 1080p-highest settings: min:56 max:170 average:103.750 *quite a lot of stuttering when respawning or turning
CS:GO 1080p-lowest settings: min:93 max:198 average:136.491 *there's less stuttering, but still some.
Unigine Heaven 1080p-High-DX9: min:9 max:225 average:101 Score:2546 *occasional bad stuttering
CPU usage in CS:GO: 55-65%
GPU usage in CS:GO: 30-40%
CPU usage in Unigine: 20-45%
GPU usage in Unigine: 100%
Interesting results I suppose... Also, it takes about 10-12 seconds to get back in csgo after I alt-tab, which I'm pretty sure is longer than on my old PC.
1 hour ago, dotz said:
ah crap, did this post die because I replied too late? I'm just going to @ everyone who posted a reply hoping it will send you guys a notification, sorry for the spam.
Yes, it's ded af bruh.
Cinebench score checks out. CPU is fine performance wise. I think it's just a CS:GO issue. Many people are reporting reduced performance lately. I guess this is an issue Valve has to solve.
@♠FlamieMeister♠ @Eibe @asiancorruption @Jasun @Komplett @NelizMastr @Hugsy Malone
With those CPU and GPU numbers in CSGO while playing something seems wrong, are you sure you have the latest stable drivers installed?
Curisosity What maps in CS:GO where you playing when this occurred and the alt-tab thing I wouldn't worry about it I takes me nearly 30sec to tab back in with a Radeon r9 200 and a i3-4130 CPU. So I assumed that happened to anyone playing fullscreen.
Some people prefer a challenge, I just band my head against a wall until my method works...
It takes me like 10 seconds to retab in, but it might be because im on an r9 270x and r7 1700x
