Cooler master hyper 212 evo
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/88787-best-cooler/#findComment-1201676
Honestly the 212 evo is pretty much amazing for the price. I have it on a stock clocked 2600k @ stock volts, folding on 7 cores 24/7, hottest it has got is 48c. That is pretty amazing if you ask me! I have them on just about all of my computers that are not on water at this point. Its a great value.
https://linustechtips.com/topic/88787-best-cooler/#findComment-1201703
^ that is true, but I have found the evo for cheaper most of the time. Well, usually when I look it has been for whatever reason. Basically my vote, whichever 212 is cheaper ;)
https://linustechtips.com/topic/88787-best-cooler/#findComment-1201725
How about the CM GeminII s524
The 212 Evo is better for the price.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/88787-best-cooler/#findComment-1201787
Honestly I would get 120mm cooler than U9B. I had that cooler for years and in the end it was louder or as loud as hdds. But I gotta admit its quality hardware. It gonna continue life in rig I built for my dad.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/88787-best-cooler/#findComment-1203105
If you can spend a little more, it doesn't get much better than the Havik 140: http://www.amazon.com/dp/B005869XYK/?tag=pcpapi-20
https://linustechtips.com/topic/88787-best-cooler/#findComment-1205983
