Power supply recomendation
Go to solution Solved by Bananasplit_00,
Just now, Nani_Sore_ said:
i live in fear now that i know the risk but it is working fine for like 8 years
if its 8 years old, all the more reason to replace it. PSUs go bad with time seeing as the capacitors age. so while yes, you can run that just fine and overclock all you want because you wont even be hitting the not 500W that it can put out max on the 12V line(the one that mainly matters) if thats your only system about $50 on a new PSU that is sure to work for quite a while more isnt too bad IMO. the CX450 is a good budget choice
Lol, an Ivy Bridge i5 and 1050Ti consuming 280W xD
Apart from the fact that the system you have there will maybe consume 125W, you would be fine with a Corsair CX450M.
Oh great so is my current psu enough then https://imgur.com/gallery/76qIn maybe for overclocking too?
yes but who knows the quality of that tbh, could go up in flames too
Builds:
A 500W PSU with 240W on the 12V rail? Put it right in a bin. And set the bin on fire. If the PSU hasn't done it by the time you find a lighter.
Oh god, so that 240W is could originally output on the 12V rail is probably down to like 200 exDee
Builds:
Urgh
Replace it ASAP with a quality one.
That one smells like utter garbage that might kill the components and/or you at any second.
"Hell is full of good meanings, but Heaven is full of good works"
