Fan Configuration
By
Lowspecgamer
in Cooling
in Cooling
Solved by Imbellis,
3 minutes ago, Lowspecgamer said:I have only 5 120mm fans can you show me a config for the Corsair spec 01 case?
I'd say that your bet would be to stick with 2 in and two out. You could add an intake on the top front, but it wouldn't make a large difference.
It may be able to add enough pressure to cause a bit less dust, but you should use filters regardless.
In short: If you already have it - throw it on.
Featured Topics
Agall ·
Posted in CPUs, Motherboards, and Memory2 -
3
xKempo ·
Posted in Troubleshooting0 -
5
Dcorrigan97 ·
Posted in Troubleshooting1 -
Davidf4e ·
4
3
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
