Have you checked if your keyboard has a standard layout?
What color(s) do you want?
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
https://linustechtips.com/topic/884660-key-caps/#findComment-10926505
whatever comes up on ebay when searching for "black chrry keycaps" or similar, you wont be getting a full set of super nice ones for $30
Builds:
https://linustechtips.com/topic/884660-key-caps/#findComment-10926528
Here is a website that vets the compatibility of their keycaps to keyboard. It looks like a standard keycap set (apart from the entire bottom row will fit). For the bottom row, it looks like the spacebar and both control and alt keys won't fit and the windows/fn keys would need a custom cap. Basically, when keycap searching you want PBT double shot injection. Amazon has a bunch, there are multiple companies that sell their own keycap sets and may have customer support where you can ask about specific keyboard layouts because so many boards are not standard.
https://linustechtips.com/topic/884660-key-caps/#findComment-10926541
Keycaps are more about preference than anything else.
That said there are things to to consider that one could feel are better than other things.
Material: PBT, POM, ABS
Print method: Dyesub, Double shot, laser etch, pad print
Thickens of the plastic.
There there are more subjective things :
Profile: XDA, DSA, SA, DCS, OEM, Cherry
Font style
Color scheme
I don't think I could find anything under $30 that I would want to use.
https://linustechtips.com/topic/884660-key-caps/#findComment-10927154
