Help very fast, urgent
Go to solution Solved by DodoDodo123,
I just went and created a new desktop and there i go to task manager and shut down gta iv, yay its k now
Hi people, I am uploading this from tablet so soory if i type something wrong...
I launched gta iv and it did not open and it gave me black screen i cant go to desktop and cant open task manager, alt f4 does not work and i cannot shut doen my pc cause i am installing a program for very long and wont start all over please help
https://linustechtips.com/topic/883443-help-very-fast-urgent/
Alt+Tab? Ctrl+Shift+Esc?
https://linustechtips.com/topic/883443-help-very-fast-urgent/#findComment-10913594
I just posted that. Anyways there is a very little chance of getting that gta IV working on your PC, if it isn't a steam version.
https://linustechtips.com/topic/883443-help-very-fast-urgent/#findComment-10913608
21 hours ago, Almostbauws said:
GTA 4 is very very bad on win 10. It took me a week of tweaking and installing weird fixes and drivers to get it working. You should be able to win+tab and then open a new desktop, then open task manager on that new desktop and close gtaIV.exe.
Yes, that's exactly what I did
https://linustechtips.com/topic/883443-help-very-fast-urgent/#findComment-10917496
It's working fine, put there are some crashes from time to time, I don't play the game very often, so it's good...
https://linustechtips.com/topic/883443-help-very-fast-urgent/#findComment-10917499
