Need help controlling CPU Fan Speed!
2 minutes ago, mrconflicted said:But the actual fans are definitely running at a high RPM, they are quite loud.
hum
ok well if thats the case then the only way i can think of of would be to use a separate fan controller but if you dont turn them up when it gets hot you may cause damage.
Try another fan header on the mobo?
Featured Topics
INotPablo ·
nugget1414 ·
Posted in General Discussion0 -
2
KN923 ·
Posted in Troubleshooting1 -
Subrand0m ·
Posted in Networking0 -
TIMEK33PER ·
Denny M ·
Posted in New Builds and Planning1 -
Theminecraftaddict555 ·
Posted in Audio0 -
