Posted January 2, 2018 Hi i have a 2 cob heat/extraction light/fan. Right now i have the "heat" lights working with a single extension cord going to positive and negative but id like to no how i can get the fan to work also and what i would need? Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 3 minutes ago, RS2007GOD said: Hi i have a 2 cob heat/extraction light/fan. Right now i have the "heat" lights working with a single extension cord going to positive and negative but id like to no how i can get the fan to work also and what i would need? Your going to have to provide more detail as what this if for and how the connections are made, can you take a photo of what your wiring up? Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 1 minute ago, W-L said: Your going to have to provide more detail as what this if for and how the connections are made, can you take a photo of what your wiring up? Ok am in process of charging phone for a photo and will post it asap. As for what its for. Its for a small nursery and the 2 - 250w heat lamps have been removed and replaced with 4 CFL lights with the extraction fan being needed for ventilation. There was also a small light in the middle of the unit which as been removed completely. Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Connect N and Fan with extension cord, or wire into existing extension cord. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author Just now, Canada EH said: Connect N and Fan with extension cord, or wire into existing extension cord. how would i go about wiring it into the existing one? Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 3 minutes ago, RS2007GOD said: Ok am in process of charging phone for a photo and will post it asap. As for what its for. Its for a small nursery and the 2 - 250w heat lamps have been removed and replaced with 4 CFL lights with the extraction fan being needed for ventilation. There was also a small light in the middle of the unit which as been removed completely. Alright so your trying to setup the device so the regular CFL lights and exhaust fan both turn on at the same time? Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 2 minutes ago, RS2007GOD said: how would i go about wiring it into the existing one? Yes you parallel them, depending on the ampere draw of course. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author Just now, W-L said: Alright so your trying to setup the device so the regular CFL lights and exhaust fan both turn on at the same time? yes Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author Just now, Canada EH said: Yes you parallel them, depending on the ampere draw of course. So i run a wire from "Fan" to "Heat"? Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 pos to pos and neg to neg, yes. Is your diagram one unit, or serparate units. Its hard to figure out what the item in question really is. Like is everything inside a case or box, or are there separate entities? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 2 minutes ago, RS2007GOD said: yes Ok that would be simple enough as said you would just run a jumper from the lights over to the fan for both the black and neutral line. If it's a metal enclosure good idea to change that extension cord for a grounded one just to be safe. Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 4 minutes ago, W-L said: Ok that would be simple enough as said you would just run a jumper from the lights over to the fan for both the black and neutral line. If it's a metal enclosure good idea to change that extension cord for a grounded one just to be safe. 5 minutes ago, Canada EH said: pos to pos and neg to neg, yes. Is your diagram one unit, or serparate units. Its hard to figure out what the item in question really is. Like is everything inside a case or box, or are there separate entities? Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 12 minutes ago, W-L said: Ok that would be simple enough as said you would just run a jumper from the lights over to the fan for both the black and neutral line. If it's a metal enclosure good idea to change that extension cord for a grounded one just to be safe. I have a 3 way extension cord but how would i go about wiring up that? Im unsure which is positive negative and you guys say jump both but i only see one N (negative?) to run both the heat and fan? Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 7 minutes ago, RS2007GOD said: -SNIP- Looks like they are using common neutral so all you would require is to have another "live" wire to jump over to the fan connection to power that on at the same time. I would suggest to replace the extension cord with a 3 prong grounded one as I see you do have connections for ground. Also make sure you trim those loose strands from the extension cord don't want something to short out. Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 1 minute ago, RS2007GOD said: I have a 3 way extension cord but how would i go about wiring up that? Im unsure which is positive negative and you guys say jump both but i only see one N (negative?) to run both the heat and fan? Oh could you take a photo of that wiring diagram, the one inside the unit where the lights are just to confirm the common neutral is correct. Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 4 minutes ago, W-L said: Oh could you take a photo of that wiring diagram, the one inside the unit where the lights are just to confirm the common neutral is correct. I see the "heat" is running through some kind of "IR" thingymabob is that bad for the CFL's? Have had one blow already after only a month or so. Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 1 minute ago, RS2007GOD said: I see the "heat" is running through some kind of "IR" thingymabob is that bad for the CFL's? Have had one blow already after only a month or so. The IR is just indicating that the unit was suppose to be using Infrared heat lamps, I assume since you don't require them that you have switched them all out to the CFL lights instead. Also it shows that there should be a light of some sort that was built in did that get removed? If you want boht the fans and now the new 4 CFL lights to turn on you would just install a jumper from the Heat terminal over to the Fan, there is no other neutral cable needed. After you can wire in the ground to the terminal labeled E for grounding. Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author Alright i may need help identifying the Positive, Negative and Ground on the new extension cord. Will find it and take a photo of it. And when you say a "Jumper" that would be just a wire running between them? Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 6 minutes ago, RS2007GOD said: Alright i may need help identifying the Positive, Negative and Ground on the new extension cord. Will find it and take a photo of it. And when you say a "Jumper" that would be just a wire running between them? Yes it would just be a short piece and insulated wire to jump or run in between the two connections. For the live and neutral connection you can refer to this, you will need to double check with a multi meter if the wires in the cord are not color coded or standard colors. Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 52 minutes ago, W-L said: Yes it would just be a short piece and insulated wire to jump or run in between the two connections. For the live and neutral connection you can refer to this, you will need to double check with a multi meter if the wires in the cord are not color coded or standard colors. I just jumped it with the 2 prong cable for now. i cant seem to find the other lead. Seems to be working though but will for sure find the grounded one at some point. Thank you alot sir Main system: i7 6700k @4.8ghz 1.45v ROG Maximus Hero VIII Gigabyte G1 980ti Sli @1500 ghz Samsung 950 pro 512gb 16gb G.Skill Ripjawz V @3400mhz Corsair H115i 280mm AIO Corsair 400c Case Corsair RM1000i Backup/Older/Toys: Intel i3 6100 @4.6ghz 1.52v Asrock B150M Pro4/Hyper Intel 750 series 400gb Radeon Rx 470 XFX Thermaltake Water 3.0 360mm AIO inWin 303 case AMD Phenom II x4 940 @3.9ghz 1.65v Gigabyte 780g mobo Corsair H100 240mm AIO Corsair Dominiator 8gb DDR2 @1066 Evga GTX 750ti FTW @1450mhz Thermaltake Matrix case (modded) "The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
