Help, Planning to upgrade
Go to solution Solved by Jurrunio,
3 hours ago, Su said:
So What should I upgrade 1st?
Missed this bit. In order, Power supply, graphics card, CPU, SSD, motherboard, RAM, case.
HI I would like to ask your suggestions on my CPU Build, I wanted to upgrade it as much as possible 1 Part at a time... I wanted to know what Part should I buy 1st for me to  upgrade.
AMD A8-9600 (Upgrading to Ryzen 5 1600x)
CPU Cooler: Default Cooler from AMD A8-9600 (Upgrading w/default Ryzen stealth wraith)
MOBO: Gigabyte AB350M - HD3 (Upgrading to Asus Strix B350 F (AM4) B350, ATX, 4*ddr4)
Storage:WD HDD 1TB (Adding 250gb Samsung 960 EVO, SSD, M.2)
GPU: Using integrated A8 (upgrading to 6gb Asus GTX 1060 STRIX OC ddr5 ROG STRIX-GTX1060-O6G-GAMING)
MEM: 8GB(2x4gb ddr4 2400 G.Skill Ripjaws V) (not yet come up with the upgrade ATM)
PSU: Deepcool DE-500W (Upgrading to EVGA 550GD, 550watts PSU, 80 gold)
Case: thermaltake Versa H13- Window Micro Atx (Upgrading to a Full Tower)
Im looking to OC in the future.
Many Thanks.
https://linustechtips.com/topic/878907-help-planning-to-upgrade/
1600X doesnt come with a cooler. Get the 1600 nonX
Not sure if the expensive 1060 6gb is worth buying... Guess that's you choice and your taste really.
Desktop benching:
I second @Jurrunio on getting the 1600 not the 1600x - more bang for the buck, and has included cooler.
I don't see the EVGA 550 GD series PSU's on @STRMfrmXMN's list.  Maybe he'll chime in on a better choice there.
Seeing that your new mobo will support 4 ram slots, maybe consider getting another 2x4gb kit to put you at 16gb total RAM.
Happy upgrading!
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
That 1060 is literally $50 less than the lower end 1070s, its a terrible buy. Either save ~$100 with a lowered end 1060 (they don't need that much cooling anyway) or save up $50 more and get a 1070
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
Of course you wouldn't - Asian spec unit
It's usually sold for the same price as a NEX-G - I wouldn't buy it except if you don't have another choice - Super Flower Leadex Gold or a SAMA Armor Gold is available for same price, or North American units.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Happy upgrading!
It's an Asian market unit and there's very little known about it. I'll add it when information is known, but iirc it's a pretty OK unit. @Stefan Payne (if I recall correctly) says it's a be Quiet! Pure Power 10, so the unit is not a bad one.
Would it be better to get 1600x and get a watercooling? Or stick to 1600? Does it have much different performance against it cost?
Happy upgrading!
I might get an upgrade on ram... So should I upgrade my MOBO 1st? And not get any GPU yet?
1600 with stock air cooler. 1600x and watercooling might push you to the 4GHz mark, but even the 1600 can do 3.8 on air so I dont think it's worth spending so much on the 1600x. Any spare budget should go to the graphics card like a cheap 1070.
Desktop benching:
Desktop benching:
Hey Thanks.
Looks like ill be investing for a 1070 then.
What could be your recommended PSU?
I actually have doubts with my PSU whenever I get GPU, im scared that it may not be enough in terms of quality/build.
1 hour ago, Su said:
Hey Thanks.
Depends on where you are buying from
 This is what we use to get a general thought about a PSU. Make sure it's tier 3 or above (though most of the time tier 1 and 2 units arent that much more expensive). As for wattage, 550w is about enough
Desktop benching:
Yeah, but not a good one either.
Can be a decent one, can be a dud. Don't know until it is tested.
There are many worse ones though...
"Hell is full of good meanings, but Heaven is full of good works"
