Upgrading monitor (DisplayPort/HDMI)
Solved by epic_ziver_D,
It really depends on the version different versions of cables won't be able to do different stuff but I prefer DP anyways because it doesn't slip out (it has a locking mechanism) and in all versions was/is better than the same time HDMI version. Also, DP does have in-line audio capabilities. (Both HDMI and DP should work in you'ur case).
Featured Topics
4
1
JFRStudent ·
Posted in Photography and Videography1 -
5
6
amir2927 ·
Posted in CPUs, Motherboards, and Memory9
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
