I was gifted a used hd 7870 gpu I have a problem that it only runs at two fan speeds at either 25 percent or 100 percent. Using msi afterburner is no help as it doesn't change any setting. I used radeon setting and that's the only place I can change settings when setting any fan speed to 20% or above gpu fans run at 100 percent  and if I lower it 19% or less it runs gpu fan speed around 25%. Auto seems to run gpu at 100 percent speed at all times making loud enough not to enjoy youtube videos or any video content I watch. Any suggestion how to fix the issue or is it a lost cause o and by the way i have already replace the fans on the gpu twice
https://linustechtips.com/topic/877758-hd-7870-fan-speed/
4 minutes ago, samladin86 said:
yes Darkseth I did but the problem is that afterburner lowest setting is 25 percent which turn my fan speed to 100 and not to actually 25 percent
I'd try to Flash the Bios with another 7870 bios so it changes fan speed profiles.
*Not for Faint Hearted, #Research
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/877758-hd-7870-fan-speed/#findComment-10863093
