As me and everyone else will say, Noctuas are the best performance but look like shit and are expensive. Honestly just get high static pressure fans and you will be A okay. Look specifically for thick bladed fans. Hope that makes sense.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
https://linustechtips.com/topic/877582-fans/#findComment-10860223
You can't really say Noctua's look shit anymore since they've got black versions with different coloured rubber pads now. But yes they sure as hell are expensive.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/877582-fans/#findComment-10860340
Noctua, Gentle Typhoon, EK and Noiseblocker are my go-tos, although of course there are others. For most projects I go for EK Vardars since I use their radiators quite often. But also Noiseblock BlackSilent Pros for their simplicity or even eLoops. Nidec's GT's are some of the best fans you can buy. And Noctua goes without saying, but because of the premium price I only consider using them on smaller builds with less fans.
Case Design | CAD | Custom Watercooling Parts | Loop Design | Cable Sleeving and Management
Fittings Guide  |  Most recent completed build: Glass & Aluminium  |  Current build(s): Project Starscream
https://linustechtips.com/topic/877582-fans/#findComment-10860347
