Extending our homes wireless network
I need some help in the networking department
Our house is decently sized, and our router is on the lowest floor, in the basement.
Most of my family uses the wifi on the floor above, and its absolutely horrible. Were subscribed to 80 down and 20 up. In my  bedroom, which is a floor above and about 30 feet away I'm getting around 1.2 down.
What the easiest way, anywhere from $0-$200, to give me speeds that I should be getting the floor above?
-I have a wired connection from the router to the floor above in my bedroom.
-Yes I've tried tin foil.
https://linustechtips.com/topic/877421-extending-our-homes-wireless-network/
have you tried powerline?
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
Ive talked to a couple guys that said they werent the greatest, kinda crossed them out of my idea list. Worth taking a look into them?
ive had a good experience with them but that's entirely on a case by case basis
try and get one from a place with a good refund policy if you arent certain
Dendrotoxin
Perripherals
Thats fair. Tomorrows the boxing day best buy run so wish me luck lol.
good luck
Dendrotoxin
Perripherals
I would say buy a switch for the Ethernet connect in your bedroom and hook up an access point. This way you have a wireless transmitter on both floors. That should help a lot.
Have any recommendations on what to get for that solution?
Ive heard ubiquiti products are good. But I have not used them myself.
Anything pretty much, as long as it says it supports access point/router modes should be enough for your needs. Same for a swtich, anything should do the job, but I like the tplink or netgear 8 port consumer models for ease of use.
Just out of interest what speeds do you get when wired into the port nearest your pc?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
So right now, in the pc plugged in im actually only getting around 45 down. Trying to figure out the problem right now, thinking that there might be 2 switches coming from the router to my pc. Miiiiight be the issue but who knows.
I havent picked anything up because of this issue.
Yeah, before doing anything else, you should check out where the speed drops off, might be an idea to see what the speed is like:-
  1. At the router directly plugged into it with an ethernet cable to your PC.
  2. At the first junction, same as above.
It could be the cables in the wall that are not up to spec, or if you already have switches, could be those... by testing at the router and the boxes/outputs you should be able to see where the problem lies.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
