HELP !!!
Solved by Energycore,
Just now, Kakapipi said:do you mean the nvidia drivers ??
Yeap. Boot on safe mode with Networking and clean them with DDU. Your motherboard should have a boot menu / boot time button visible either on the first screen you see, or on its manual. There you can select safe mode with networking so you can download Display Driver Uninstaller.
Featured Topics
techfan84 ·
Posted in Troubleshooting1 -
jeanssullivan ·
Posted in General Discussion2 -
Krzysztoff ·
Posted in Laptops and Pre-Built Systems0 -
15
12
