Ive had HyperX cloud 1 since they first came out looking for upgrade since its Christmas.
Considering Corsair VOID Pro RGB Wireless Gaming Headset
Considering HyperX Cloud Alpha
Considering Other options I don't like razer they don't fit my head well, also nothing to "gaming" looking, just comfortable and good audio, Not a huge fan of Logitech. All Options appreciated.
Listen, Smile, Agree.
Then do whatever the fuck you were going to do anyway
https://linustechtips.com/topic/876253-100-or-less-headset-wmic/
The hyperx alpa i think is a good choice. They are coomfortable, not to flashy and have great sound. I have not used them on ps4, but they should work on ps4. They only thing i can think of that can be a minus is that you dont get the external sound card you get in the HyperX cloud 2 headset.
 But all in all i think it is a great choice.
https://www.massdrop.com/buy/massdrop-x-sennheiser-pc37x-gaming-headset
The Massdrop x Sennheiser PC37X.
Really good audio and microphone. Semi-open back. Very comfortable.
It's 20 dollars over your budget but if you could save up just a little more it'd be worth your while.
