Cable Management - Phantek Enthoo Evolv itx
Solved by seon123,
Just now, 22hs22 said:Thanks man I'm trying not too go to cheap on PSU, but damn PSU can get pretty pricy as well.
Ive read that the gigabyte mobo vram heats up as well(which is scary in an itx case) but I hope it happens only when overclocking and i dont plan on overclocking atm.
Yeah, it's got a pretty tiny heatsink. The stock cooler should provide some airflow over it, so it should be fine. It's not like Ryzen draws a lot of power.
