SLI vs nvlink (for quadro)
Solved by Jurrunio,
8 minutes ago, DGC said:Well you got me... I was going to use these cards for gaming because I am cleaning out a graphic design studio and the manager said that I could keep graphics cards, but I want to know which would be better for gaming
welp the NV link bridge is only used by Volta cards (Titan V has a much larger connector on the top as shown in pictures you can find on the internet) so the much cheaper SLI bridge is all you need. Also Pascal can only go 2-way SLI so one of the cards can stay outside. However, does your motherboard support SLI? Do you have the power supply to power them?
